losing fuel on hard launch?
Old 11-04-2013, 05:24 PM
c-ham's Avatar
Default losing fuel on hard launch?
ok so last time at the track if the car "slightly spun" as in low 1.52-1.54 60' it would launch fine, but if it hooked hard (1.48) it would hike the tires 6" then momentarily "Shut off"/lose fuel then go again. the car had like 3/8 of a tank in it and has aeromitive 340lph stealth pump in it. it is a 98 camaro with stock metal tank. I also notice if i get undr 1/8 of a tank it will die when i hit the brakes to long or turn to fast? is something wrong with my tank and is there a way to fix this?
Old 11-04-2013, 06:14 PM
AKAFRED's Avatar
mine under 1/4 tank does that, i was running twin turbos for a while and installed twin intake pumps, when i did that i had to ditch the basket.. that is my problem, may be yours also.
Quick Reply: losing fuel on hard launch?
