Diesel Truck Turbo? Yes or No?
Old 11-06-2013, 01:09 PM
kward's Avatar
Default Diesel Truck Turbo? Yes or No?
New to the forum and trying to gather intel for my LQ4/4L80 build in a 69 Camaro. Just curious if the turbos on the 6.0 and 7.3 diesel trucks are an option. Any input and help is appreciated.
Old 11-06-2013, 01:45 PM
AmishAssassin's Avatar
Default Good motor wrong turbo.
I am sure it has been done before but I wouldn't advise it, you can make anything work. However I would go with a PT78 and call it a day. Pictures would help you get more responses. Best of luck and welcome to the forums.
Old 11-06-2013, 01:47 PM
Compressor Surge's Avatar
Light truck diesel turbos won't work as a single...maybe as twins.
I had a Cat C15 (15 liter) turbo on my 5.3 for awhile. Basically a BW S400 with a huge 1.58 A/R on the hot side.
Old 11-06-2013, 01:51 PM
BMF_Racing's Avatar
Some have done twins (single is too small) off a cummings because they had them, but if your buying these there are much better choices. good luck.
Old 11-06-2013, 06:53 PM
SSpeeDEMONSS's Avatar
i've worked with plenty of diesel turbos, on diesels, and i wouldnt use any light duty truck turbo on a gas engine. like said, medium and heavy duty truck engines have turbos closer to the size you would want. i regret getting rid of all my TV7512s that i used to have.
Garrett
Old 11-06-2013, 07:06 PM
dezlfrek's Avatar
a guy here has 2 hx35's(off 1st and 2nd gen dodge) on his car running 9.40.. And im not sure if most of you guys realize almost all the turbos we are using were designed for diesels. Do you really believe these companies would make all these turbos we use just for the limited aftermarket. Im just saying.
Old 11-06-2013, 07:40 PM
BRUTL's Avatar
I'm pretty sure everyone above already said twins might be an option, which is exactly the scenario you gave...
Old 11-06-2013, 08:42 PM
Mt.Dew's Avatar
I'm putting a pair of Hy35's ( 5.9 cummins) on my 5.3 right now. If you run a search, LilJon ran a pair on a big block and it was "Nasty".
Old 11-07-2013, 08:57 AM
Oh wow! Thanks, I didn't know that.
Quick Reply: Diesel Truck Turbo? Yes or No?
