Are the LT1s worth keeping/modding?
Old 11-07-2013, 07:19 PM
Bow Tie Power's Avatar
Default Are the LT1s worth keeping/modding?
I had planned on modding my LT1 (after I fix the random stalling issue) but I've heard there are quite a few issues with these, such as the opti, opti harness, ICM etc. I'd really like to know because I'm not sure I should keep this or swap the 5.3 I thought about buying and swapping it in.
Old 11-07-2013, 07:40 PM
Vicious95Z28's Avatar
The LT1 still has a whole lot to offer. Aside from the distributor issues they really are great engines with lots of potential, just like any other SBC. If you have the cash the distributor can be completely eliminated these days.
Old 11-07-2013, 08:04 PM
Man-Crush Warning
Shownomercy's Avatar
Ditch it and go 5.4 mod motor
Old 11-07-2013, 09:29 PM
devildog214's Avatar
Lt1s are nice because they are dirt cheap, you can make anything as fast as you want, but dollar for dollar an LS will give you more. But swapping an LS into an LT is really a pain, all my import friends are just like "dude you should totally just drop an el es juan in there brah" and then I have to explain that even though the cars look similar LS and LT fbodies have alot of differences especially when swapping motors. Your better off finding a blown up LS car or perhaps a LS shell that still has the good bits left in it (wiring harness, k member and mounts, etc, etc. If your LT car is mint, if you like the bodystyle, want a sleeper look, and have the time for a bigger project, then ls swapping may be worth your while.
Oh and apart from lt1's being unreliable there are a huge number of high mile lt1s around me included, 165k and Im on my 4th opti, its a wear item and they usually last about 50k or so. But my last opti was replaced from misdiagnosing some bad plugs and wires.
Old 11-07-2013, 09:49 PM
Almonz T/A's Avatar
LT1's are fantastic motors, sadly they do live under the shadow of the LS1. As far as the opti goes, 95-97 got the vented opti so they were much less prone to failure. However like others said, the 93-94 opti can be replaced with a much more reliable opti.
Even though buck for buck the LS1 does outrank the LT1, by no means is the LT1 bad. Some serious power can come from the LT1. Bolts, H/C and a good tune can easily net 400+HP. Gearing, stall, etc. can all be applied to an F-body whether it's LT1 or LS1. Most of the time, an LT1 will satisfy someone's power needs. Unless you need serious power or just want to have an LS1 an LT1 is just fine. Plus they seem to just sound better than the LS1s
As far as reliability goes, it all comes down to the owner. I always say to treat your car the way you want to be treated. If you take care of her, she'll take care of you. I've seen mulitiple LT1s going strong past 200k so reliability isn't a huge issue with them. They are a 350 after all
Old 11-08-2013, 01:28 AM
Fly on the wall's Avatar
Damn straight they do. I had a '03 vette that was cammed. Put it next to my cammed '93 and it sounds like an import. Both had similar sized cams. I sold the '03 and never got a clip of it, but here is my '93 after a plug and wire change:
Old 11-08-2013, 02:12 AM
93Z2871805's Avatar
While the LS is a fantastic platform (I just did the swap from LT to LS, not too much of a hassle, took 24 hrs from running LT1 to running LS3 headed LQ9), the LTX platform still has plenty of bite (hell, one member on here is getting ready for some 7.5x passes on a production block). The LT1 that came out of my first 93 is now making 465 at the crank with nothing more than a 750 Holley, Accel HEI dizzy, and a VERY mild cam in a 72 Nova. I myself am considering buying another LT Fbody (I personally feel the LT1 has better low end grunt than an LS, and I also personally like the sound of an LT better). If your considering an LS swap you wont be disappointed. If you keep the LT you wont be disappointed (I do hate the opti though...lol). Check out some of the members' cars in the fastest list sticky, it'll make you think twice about how potent an LT can be. One off of the top of my head is RamAirTA, he's turning 10.8x's out of a full weight TA with a 383.
So, to answer your question - Yes, they are worth modding. It just depends on what exactly you want to do with the car.
Old 11-08-2013, 07:59 AM
HellTeeOne's Avatar
I for one think the opti problems are blown way out of proportion. Convert to a later-style vented unit and get a OEM GM part and you have little to worry about, particularly if the car is not a daily driver.
I bought an LT1 car way back when because I liked the body style, sound and character of the car better than the LS1 stuff. 13 years ago when I bought my car LSx tech and aftermarket was sort of still in it's infancy as well and the modest difference in performance between the two platforms just didn't matter much to me, and still doesn't.
It all comes down to personal preference. Most people these days don't give the LTx a second look and you'll find that most people who are still messing with them have been doing so for a number of years now. Not many newcomers to our little world over here in LTx land these days.
Old 11-08-2013, 08:11 AM
93M6Formula's Avatar
The Opti B.S. is way out of preportion. I replaced mine at 88K for no reason honestly, was chasing down a different issue. My new GM Opti has been on the car for 30K miles without a hickup. 100's of track passes, driven in heavy rain etc etc you name it. All on a non vented Opti.
In my opinion, half of the failures are because of negligence, stupidity, and people not knowing what they are doing. On top of that, you only hear of BAD opti stories because noone comes to a Forum to tell everyone about how good their opti is or anything else for that matter. You only hear of the problems and negatives and then the word spreads like wildfire and everyone thinks it's junk.
Old 11-08-2013, 08:15 AM
moderate Z28's Avatar
I will tell you how good my optis are lol. Ive had 3 of these cars. Been driving an Lt1 or 2 for the past 12 or 13 years and Ive never had to replace an opti. Its blown way out of proportion. I find them to be pretty reliable engines. I do take good care of mine and I will always have atleast one. Bang for the buck you just cant beat em.
Old 11-08-2013, 08:16 AM
Stuff like this bothers me, you "heard", you "read" they had issues. FYI, every vehicle ever made has issues, you can't get away from it. The only thing you can do is hope yours won't have problems or don't worry about it, it's a man made product, nothing is perfect. LS1's have issues of their own too.
But I am glad you came to ask instead of just going off of what you saw.
Old 11-08-2013, 08:24 AM
Exactly, you can get these cars for a dime a dozen. I run my car hard at the track and on the street too and use it for what it was intended for and the motor runs flawlessly, no smoke, no knocks, great oil pressure. They can take it. For example, there's no such thing as an aftermarket LT1 block, all the fast guys running 9's or 8's are on the stock block, you can't argue that's pretty impressive.
Old 11-08-2013, 10:43 AM
sweetbmxrider's Avatar
My fully built lt1 can barely keep up with cam only ls1's, nevermind heads cam setups. I'd go ls and have a very fast, very reliable platform that people will think you're cool for having when you pop your hood.
Old 11-08-2013, 11:53 AM
moehorsepower's Avatar
Fully built LT can barely keep up with a cam only LS? What do you mean by fully built, and if that is so then that is a poor example, Looking cool when you pop your hood? well paint your LT Purple and that will look cool (To some folks) My LT has stock heads, no aftermarket, stock intake, no sheet metal, opti and a turbo and as of now makes 703HP on low boost and conservative tune with room for more, I love my LT!
The reason why I'm saying this is because I've had a '95 z28 that never had a single problem. (Seriously. I changed the spark plugs and wires, and gave it oil changes. That was it. It needed nothing.) But my '94 Firebird Formula has had nothing BUT problems! I bought it in May and have had issues ever since 6 days after I bought it. People can't say I abuse it or mistreat it because, believe it or not, I'm almost a grandma driver. I baby the hell out of it and very rarely get on it. I've just had one problem after another and I'm so sick of it.
Old 11-08-2013, 12:03 PM
Sorry, it is a poor example (my car that is) but it is an example. If you want to bring super and turbo chargers into the argument, well hold onto your doors!!! Them gen 3 make 1000 all day long!!! I did paint some stuff green on my motor, but its no ls1
Old 11-08-2013, 12:06 PM
Man-Crush Warning
It is quite green.
Even my turbo Lt1 gets beat up by cam only LS1 cars.
Old 11-08-2013, 12:57 PM
Mighty Whitey's Avatar
Starting off with a stock lt1 car today, I would sell of the motor and go but an ls motor of some sort. Best bet would be buying an Lq4, and a set of take-off 243/799 heads.
I bought a complete, ready to run lq4 for less than the cost of the efi connections 24x kit, including the cost of the PCM, coils, 96-97 front cover, and potentially someone else to convert the wiring harness.
A stock ls1 k member and rack can be had for around $100 if you search around.
Anyone can debate the price of an ls motor, they're anywhere from $150-3500, but the price of the 24x kit is set in stone. And to me it's just not worth pumping close to $700 in to a motor like that.
Old 11-08-2013, 01:27 PM
I8ASaleen's Avatar
5.3's are cheap. A cheap Heads/cam and turbo system would be your best bet. That is of course if you have access to the wiring harness and computer, with a k-member and a transmission that will mate.
It won't be any easier to work on though, the cramped engine bay does not allow you much knuckle space. If I were to do it over again, I'd get a cheap 5.3 with a build 4l80e, then put heads/cam and turbo on it.
Old 11-08-2013, 01:34 PM
I am going by you saying "A Fully built motor" to me, thats after market heads, or at least ported stock ones, up graded pistons, cam, crank ect. A fully built LT are making 450- 500 + RWHP, a "cam only" LS isnt going to make that. I agree it is easier to make HP with an LS motor and yes you can get the 5.3, slap a turbo and make huge horsepower, but maybe you need to describe your Fully Built Motor..
Quick Reply: Are the LT1s worth keeping/modding?
