Is it worht using the sea foam?
Old 05-06-2004, 02:17 PM
2000SLVR_Z28's Avatar
Default Is it worht using the sea foam?
I have some knocking in the intake. Some people of recommened using the sea foam.
Old 05-06-2004, 05:23 PM
Z06PSI's Avatar
I know there are alot of moving parts inside the intake.....
Seriously..... yes a top end cleaner works well in our cars due to the crappy PCV setup......
Old 05-06-2004, 05:25 PM
Yelo's Avatar
Seafoam ROCKS !!!, it cleared up ALOT of top-end noise problems I was having
Old 05-06-2004, 10:44 PM
Camaro01SS4life's Avatar
I used sea foam the other day in my intake...All I can say is WOW!!!What a difference...I also installed the AMW catch can as well...Don't forget to change the oil ...
Kevin
Old 05-07-2004, 05:51 AM
mcflyz28's Avatar
Where did you get the Sea foam, sounds like something I should do as an oil change is coming up along with a catchcan.
