Underperforming le2's?
You 60-330 shows you spun on the first run, second run shows you hooked but must have let off since your 1/8th mph was higher yet 1/4 was lower. Reaction has nothing to do with ET. You dynoed 385 IIRC, which is a bit low compared to some of the higher (12.5ish) compression AI 200 cars. I definately think the compression is holding you back.
9-Second Club
Can't see a guarantee like that when you don't know how sharp the engine builder and tuner might be. Just because they will SUPPORT that much power certainly does not mean a given engine will make that much. More to it than having a local machine shop machine everything and bolting one together.
Man-Crush Warning
First pass I had 21 psi in the rears and spun, probably were a little cold too. Started hooking at 19 psi and a little more heat. That second slip I left the car in overdrive like a newb, heard it shift, and got out of it
The air was really good. I can't decide if I want to max this setup out or what....guess I have all winter to pile up boxes It was fun driving to the track, swapping wheels, running 10s, and driving home. Weight was like 3370 with me and around 3/4 tank. I thought it was pretty cool for little ole hand ported le2's.
