GM 10 bolt 1.5 Rear End Girdles on sale !!!!
GM 10 bolt 7.5 Rear End Girdles on sale !!!!
$122.95 SHIPPED !!!!!! Only at www.neweraperformanceparts.com
Strengthen your GM rear end with the strongest rated support covers you can buy !! These 356 T-6 Aluminum covers help keep the rear end housing from distorting under load , preventing increased side bearing clearance and ring gear deflection . Two special adjustable grade-8 support bolts help prevent both bearing main caps from movement and possible breakage . Increased fluid capacity , fill , drain plugs and hardware .
While supplies last !!!
Thanks ,
Mike
sales@neweraperformanceparts.com
585-865-1832
Thanks ,
Mike
585-865-1832
Do these things really work? I can't see how they would help from snapping your ring/pinion... is there proof that they help? Also, will it clear an aftermarket panhard rod? That's a good price...
In conversation with car guys and a couple of vendors, they say it assists in keeping the rear together longer......no guarantee......just does a little pre-load in the rear end area......I am going to order me one to try and prevent busting them old 4:10's gear in the ten bolt. Hope this explanation helps some. cheers......
Kent1 is correct , it also will make it easy to change the oil in your rear end as it has a drain plug and fill plug .
Mike
585-865-1832
Mike
585-865-1832
Only got a few left .
Mike
585-865-1832
Mike
585-865-1832
We just got a bunch more of these in and we are going to try to make this sale go for a little while longer because there is a price increase coming up June 1st on Mac Performance Parts .
Thanks ,
Mike
585-865-1832
Thanks ,
Mike
585-865-1832
Sale still going , got 20 more at this price .
Thanks ,
Mike
585-865-1832
Thanks ,
Mike
585-865-1832
Yes , they are still available , we have about 13 guarranteed left at this price right now .
Thanks ,
Mike
585-865-1832
Thanks ,
Mike
585-865-1832
I am sorry , but I really would not know that .
Thanks ,
Mike
585-865-1832
Thanks ,
Mike
585-865-1832
Moderator
This cover comes with the studs already... they have
little pivot feet on the studs and the design is nice.
Originally Posted by Nesto
seeing that its the same design as other girdles would the other stud kits fit this as well ?
