335/35/17 on 17X11s
I only had to hit the inner wheel wells wear my tires BARELY rubbed on hard turns.........with 315/35/17 tires. Literally hit each spot about 4-5 times. 1 minute each side. No rolling of fender wells either. I just removed the bump stops.
335's will fit if you bang a little bit more and use a 1/2" spacer.........
well I'm lowered so that may not be an option. Other than doing a widebody like the 30 beautiful Dick Harrell camaros... but I don't have money for that now so 315/35s it is I may go with a widebody later but definitely no tubbing... daily driver.
They'll fit without a tub, but not without a **** ton of massaging. My response was based on "doing it right" to make them fit. Too much in my opinion just to get a look....but hey, it's you car. Hammer away
https://ls1tech.com/forums/14477926-post4.html
