Quick question for you guys. 370|9.2:1 motor, TH400
I've been on Tech for some time, been reading A LOT and am finally about to start my build after dusting it off the shelf.
My motor is getting cleaned up at a machine shop, 370, 9.2:1 minus the heads. 317's with 5 layer gaskets, cleaned up with patriot duals with a TU2 cam.
Sticking behind it is a TH400 with a 3200 stall. I *THINK* it'll be a 28" tire? 315/35/18. I'm no tire guy, rims will be piano black Forgestar F14's, deep concave. 18/10 fronts, 18/11 rear.
Car isn't built yet, but motor is getting done and we'll be ripping into her shortly.
My question is, I have a T4 truck kit that was built by KYTP PRIOR to his mess. The turbo I currently have is a T4 TC78. I'm not sure that'll be enough, I know I want a BW unit, but not sure on what will physically fit once the radiator is in. Any suggestions? Thanks fellas! Money is no option, I'm going to build this car the right way once lol
We are not exactly sure what you're asking here. What about the TC78 won't be enough? And do you want input on fitting a BW behind the radiator? Would probably help to know what car its going in to give a straight answer on that.
The car in the Sig pic. I just don't want to go through the Hassel of putting my car together to find out the turbo is in deed the weak link. I would like to drop in a BW T4 in there, but I gessnill have to do that after I get her lined up and see what it all does and go from there.
Nobody can recommend a turbo without knowing your goals. For someone to say a TC78 is too small for a 370 is blasphemy. Size the turbo according to what you want out of it, not your engine.
If there is a option for billet in a S400SX-80 in a T4...go that route. But just know the 800-900 hp range is just in its sweet spot. Any BW unit from s475-80 will get where you need. Quite honestly just call Jose up at forced inductions and ask. He will know for sure
