ARP head stud users inside...
1 Post
Re: ARP head stud users inside...
I would like to know also.
Also do they use the same torque patter as regular head bolts?
I'm sure a sponsor like ARE, MTI etc that installs these regularly can answer these questions in a second.
The ARP paper that came with my head studs says to torque to 70ft/lbs with molylube or 85 with 30wt motor oil. Good luck. Jimmy
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by joghotrod:
<strong> The ARP paper that came with my head studs says to torque to 70ft/lbs with molylube or 85 with 30wt motor oil. Good luck. Jimmy </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually, if you read further down, it says for Aluminum heads, to use 65 ft/lbs to account for the expansion. Either way, it probably doesn't matter. I used 65 though.
And I followed the same torque pattern as regular head bolts.
!Dial-up Director
Studs get 5ft/lbs and the nuts get 75ft/lbs with the moly lube, stock head gaskets. Checked them recently and they are all still in spec.
Justin
Justin
