Nitrous Oxide - Direct Port Fuel System Write-Up Moving Along
Reckless
01-24-2003, 09:01 PM
It's so damn cold, I can only get a little done at a time, but it's getting there:
www.cofba.org/users/reckless/dp_fuel.html (http://www.cofba.org/users/reckless/dp_fuel.html)
W8N2SQZ
01-25-2003, 10:46 AM
Nice work Todd <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Glenn
FastBlackTA
01-25-2003, 10:56 AM
thanks a bunch for taking the time to do this write up. I'm planning on building a driect port once i assemble my 427 stroker (cartek is doing my machine work as we speak).
anyway, good work! <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Todd, nice to see your still fabbing things up. Nice work so far, what size you going to run?
You know you still have the BSM record right? Hopefully myself or one of the guys will be breaking that early this spring <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . I am looking at using the NXL, walbro 340m, NX Pro. Controller. Bode is hooking up the new pump and roll bar in about 6weeks, then I will order the NXL and controller. Heard a lot abut and continue to "the mad combo swapper" mostly. Good-luck, I'll be checking to track your progress.
BSM 96.
Darren
01-25-2003, 08:30 PM
Todd,
Love your set up. I am doing the same set up as you. I bought the jaz one gallon tank. I will be taking out the coolant jug and cutting to fit the tank. Mike will be sending my NXL in two weeks. I will be using the digital controller to activate the system. I am hopeing I get mid nines with full weight. It a 422 with a trans brake 350. I will take pictures.
Good luck.
Darren
Reckless
01-25-2003, 09:14 PM
Thanks Glenn!
No problem FastBlack...hope it helps you out!
CAT3....Bode will take good care of you. Sounds like my record won'y stand for much longer <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Darren....some other have used the JAZ Junior Dragster cell which is 2-quarts I believe. Only thing is you have to replace the petcock with a buulkhead fitting and make another fitting for a return line if you want one. I had thought about cutting things to fit this cell, but figured it was easuer to downsize the cell.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Todd
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
