LS1 Idle issue please read
I am currently having an issue that as i come to a stop with the clutch depressed my idle will drop down to as low as 200 rpms. the car run and drives fine. no high idle or anything along those lines.. the only thing i have done in recent time was a coolant flush and refilling. Another thing i noticed was that although my temp guage says i am at full running temp my air still blows very cold. my air conditioning does not work as it has a leak. i am just curious as to what would cause my idle issues. i have read about IAC and so on but as i am enlisted military my pockets arent as deep as i would like to be buying new sensors for them not to be the real problem. Could i have a bubble in my cooland system? or something else i can look for before i begin purchasing sensors? any advice or redirection would be great.
Thank you,
Lcpl Connor, Christopher
USMC
Thank you,
USMC
Thank you,
USMC
Thank you,
USMC
I'm sorry for my lack of detail on that one. In my bit of frustration i completely neglected that. It is a 2001 Camaro SS. I will clean the IAC this week as per direction from johnson73801. Another small detail that i just worked out was that while my car shows fully warmed up at 220 degrees my heat was still blowing cold. but as i drove the heat did eventually begin to work. it seemed that the car showed full operating temp but it was not actually warmed up. not sure why it would act this way. it is troubling being where i am lol back home i could lay my car up and take time to investigate. i greatly appreciate the replies back and will keep updating with the moves i make on the car to repair it
