Pulling parts for my swap from an 02 Tahoe
I'm pulling the engine from an 02 Tahoe to swap into my 99 Mustang. I pulled the engine, ECU, gas pedal, wiring and pedal harness, and the engine harness. Is there anything else I need to pull? What about the big fusebox under the hood, and the wiring that goes to it? What about the OBD plug under the dash? Any more wiring behind the dash I may need? Just wanna make sure I get what I need while I have the opportunity. This is my first swap. Thanks
Get the OBD2 plug and the TAC module that the pedal harness was plugged in to.
The fusebox is pretty bulky. For $20 you can get a smaller box and relay set that will package much easier.
