1967 camaro ls swap
Old 11-11-2013, 11:33 PM
1967camaro78's Avatar
Default 1967 camaro ls swap
I have just started my swap pulled "old" engine only around 500mi since install was a fuel injected 327 with turbo 350. Now the new for mock up 2008 LFA 6.0 with ls3 heads and a very big cam. Here are some pics as of now. 1967 camaro ls swap-0813092141.jpg
Old 11-11-2013, 11:36 PM
Old 11-12-2013, 12:44 AM
bmf5150's Avatar
Very nice
Old 11-12-2013, 12:57 AM
Thanks wish pictures were bigger but not sure why the loaded so small. Getting ready to buy harness next. Any one bought from PSI? They have harness ls3 dbw for $625 and tcm for 4l60e for $75 programmed with my tire size and gear ratio.
Old 11-16-2013, 09:19 PM
About to pull trigger on harness and tcm does any one have promo codes for PSI?
Old 11-16-2013, 09:43 PM
lsx67's Avatar
Nice build, in doing a similar setup, 68 with a 6.0. What oil pan, mounts and headers are you running.
Old 11-16-2013, 10:48 PM
kelsey_canard's Avatar
Also interested. I as well have a 68, and the 5.3/4l60e out of my truck. I would love to swap it in.
Old 11-16-2013, 10:56 PM
406chvycamaro's Avatar
Im currently doing an ls 6.0 swap into my 68 camaro too. I used the trans dapt motor mount adapters, dynamax headers, and the gm performance oil pan
Old 11-16-2013, 11:12 PM
I used dougs headers and mounts. Those seam to be ok so for. The pan is muscle car pan from gm it is currently touching sub frame in front and pan looks pretty deep at back may have to choose another option.
Old 11-16-2013, 11:19 PM
Mine was also touching the sub-frame initially. I put a washers between the adapter plate and motor mount and it fixed the problem
Old 11-16-2013, 11:21 PM
Great minds think alike. That is exactly what I was going to do next. How many did it take?
Old 11-16-2013, 11:30 PM
I started with 2 but had problems with it lining up with the mounts. I then pulled it out and went with only one and it worked great. Also had enough clearance to run factory ls1 low mount alternator
Old 11-16-2013, 11:43 PM
Good to know. I will try that. As for alt I am running ctsv serp kit from gm and it is also low mount. I will probably have to cut a notch in frame to clear it.
Old 11-16-2013, 11:45 PM
Do you have any pictures of install? How low does your pant hang past sub frame?
Old 11-16-2013, 11:46 PM
Leadfoot85's Avatar
Not sure if you've bought your harness yet, but PSI makes a good quality harness! I got one for my 5.3/4l60e combo as well as a programmed ecu for $699. The harness is well made and lays out really nice on the engine. I highly recommend them!
Old 11-16-2013, 11:50 PM
I have not bought yet but I will. As for programming I will get a base tune from a local shop here and take to dyno after all is done. Quoted $795 for base tune and vats delete and dyno time and tune. Sounds like alot of money but is a big time saver on tuning.
Old 11-16-2013, 11:52 PM
I don't have any pics currently. But if you want to pm me your number I can take some and text them to you. The oil pan hangs down a good little bit below the crossmember but not anymore than the long tube headers do.
Old 11-16-2013, 11:57 PM
That's good I hope I can use this pan was a good deal because I work at gm so my cost is pretty awsome so hate to buy aftermarket parts unless I have to.
Old 11-17-2013, 03:51 PM
As far as 4l60e did you have to get a different cross member or did it fit when engine was pushed forward? Drive line have to be cut down too? I was running turbo 350 but did have to cut drive line down when I installed 12 bolt. Also is slip yoke the the same on 4l60 as a 350? My trans is at my buddies house being built still.
Old 11-17-2013, 06:02 PM
Sorry didn't have a chance to take any pics of it today. I'm running my turbo 400 behind it for now
Quick Reply: 1967 camaro ls swap
