Converting from M6 to TH400 - 1 quick question
On the M6 the clutch has to be pushed in to start the car. With the converstion (now no clutch) what is the easiest/quickest way to by-pass the clutch cut-off? Can the cut-off be removed and wired together?
Thanks
David
Thanks
David
just bleed all the fuild out of the line and the pedel will go all the way to the floor. this is what i did. i didnt what the pedel up so i would not get confused.
You can just tie the two wires together. You can also run those two wires over to the nuetral safety switch on your aftermarket shifter, nothing will surprise you more then reaching through the window to start the car and the car is in reverse or drive
FWIW you will get a SES light eventually from it, the PCM expects to see some clutch activity. Easily removed with edit though.
Thanks
David
Thanks
David
prndl switch must have contacts and wires large enough for starter solenoid
amperage draw.earlier model big purple wires if i recall?john
n/s switch
Originally Posted by johnhaver
switch is normally open,if u connect wires,itwill start in any position!!!!!!!
