10 bolt rear
10 bolt rear
Category: Drivetrain
Price: $175
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): CT
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
now the reason why its for sale. ive been dealing with a driveline vibration/clunk recently. originally i thought maybe it was the rear however last time i took the car around the block, the transmission was clunking so badly when changing gears that im about 90% sure thats my problem. There is still a small chance that it could be the rear but i dont believe that to be the case. when rotating it by hand forward or backward, everything turns nice and smoothly and it feels great. fluid was also super clean when i first opened it up. once you receive it all you need to do is put your brakes on it, install the c-clips, the pin, and the bolt and you should be good to go. those parts are all included. this rear was run with an auto trans car and with a TA Performance girdle with yearly fluid changes.
