Problem
Problem
my 93 z28 wouldn't turn over after removing the plugs the third cylinder on the passenger side was filled with gas. i removed all the injectors cleaned and replaced all the o rings, and put it all back and went to fire it up and it ran for a second i shut it off went back out to the car tried to start it and once again it wont turn over and it acts like if filled the cylinder up again, any ideas on what this could be?
9-Second Club
Empty that cylinder, start it back up, unplug that injector. Let it sit a while, then pull that plug & spin it over to see if that cylinder is full of fuel again. If it is the injector is stuck open, and needs replaced. If you got it unstuck I would not trust it again.
If not, key off, connect a test light across the terminals in that injector plug. If it lights you have a grounded injector wire. The '93 is not sequential so it won't be an injector driver in the ECM.
Good luck.
Good luck.
When i took the the injectors out i replaced the injector that i thought filled the cylinder up. third plug back on passenger side was filled so i replaced the third injector back on the passenger side?
My bro bent a rod in his Hemi when his cylinder filled with gas. Be careful..
