Fuel return question
Old 11-19-2013, 08:53 PM
rodster56's Avatar
Default Fuel return question
Hello everyone, I have a pretty easy question. I am installing a 2004 GTO LS1 in a 54 Cadillac. I am using a Walbro in line pump into a Corvette style bypass filter. The return line off the filter, can I pipe that right into my actual fuel filler tube that goes into my tank so the return fuel would "run back into the tank" in essence? Also what fitting am I looking for to adapt the ends on that filter to 6AN lines? Thanks in advance!
Old 11-19-2013, 09:07 PM
erickcastillo95's Avatar
i think that would work with no problem but i dont know what fittings you would need good luck on the find
Old 11-20-2013, 05:07 AM
Pop N Wood's Avatar
Just make sure you aren't using the fill vent for that otherwise it may cause problems filling it up.
Old 11-20-2013, 05:40 AM
casias's Avatar
Here is one with the adapters
http://www.ebay.com/itm/LS1-LS2-LSX-Conversion-fuel-filter-w-regulator-6-AN-/161153751201?pt=Motors_Car_Truck_Parts_Accessories&hash=item25858318a1&vxp=mtr
you can also buy them separately. You need 3/8 and 5/16
http://www.ebay.com/itm/RUS-640850-Push-On-EFI-6-AN-Male-To-3-8-Hardline-Fuel-Fitting-Blue-LT1-LT4-LS1-/260886318853?pt=Race_Car_Parts&hash=item3cbe094f05&vxp=mtr
Summit, Jegs, Speedway also have them.
As far as returning your fuel to the filler neck. No troubles as long as it is far enough down to prevent splashing up near your cap.
Old 11-20-2013, 05:49 AM
rodster56's Avatar
Cool...Thanks Casias!!
Quick Reply: Fuel return question
