1993 Turbo 240sx street legal track car
Year: 1993
Make: Nissan
Model: 240SX
Price: $7500
Mileage: 132000
Private or Dealer Listing: Private Listing
Location (State): AL
Color: White
Transmission: Manual
Drivetrain: Rear Wheel Drive
1993 Nissan 240sx Slicktop
$7,500 [/email]
$7,500 [/email]
SOLD
Engine:
KA24DE-T has 6000 miles on it since rebuild, internals good to 500+ hp, turbo seals are going out so it smokes after hitting boost.
Arias pistons
Crower rods
New rod and main bearings (ACL)
ARP head studs and main studs
balanced crankshaft
OSK timing chain kit
New oil pump
Refreshed cylinder head
New front and rear seals
S14 upper intake manifold (flows better)
S13 lower intake manifold
EGR deleted
ISIS T25 cold side T28 exhaust side on the turbo (Smokes)
Isis bottom mount exhaust manifold
ARP Manifold to Turbo studs
Front mount intercooler
Blow thru N60 mass air flow sensor
SR20DET 370cc injectors
Enthalpy rom tune
NGK Iridium cold plugs
Full 3 inch exhaust
Aluminum radiator with electric fans and shroud
Silicone radiator hoses
Spec stage 3 clutch Fidanza flywheel
J30 VLSD
Autometer electric water temp, oil pressure, and boost pillar gauges
Walbro 255
Polyurethane engine mounts
Lightweight pullies
Magnetic oil drain plug
Body:
PPG Pearl White
Type X OEM front bumper with fender extensions (not pictured)
Rolled and pulled rear quarter panels
Rolled front fenders
Shaved windshield washer nozzles
Shaved rear brake light
JDM Kouki Tails
Hood pins
Interior:
S14 seats and seatbelts
Carpet
All gauges work
4 point cage weld in roll cage
No radio or rear interior
Suspension/brakes:
JIC Coilovers
MB Weapon Wheels
5 Lug
ISIS tension rods, rear camber arms, rear traction arms, rear toe arms.
Megan Subframe spacers
Aluminum 300ZX brakes all 4 corners (Stops on a dime!) No e-brake
Braided stainless conversion lines on all 4 corners
Slotted and cross drilled rotors
Clean title in hand! 132,000 original miles, power windows, power steering, power brakes, wipers, and all lights work. It has no a/c, radio, insulation, or heat. Chassis wiring is thinned out and tucked in the frame (no longer in the wheel wells) Fuse boxes are all under the dash. It is street legal but is a still car and loud, not very comfortable on the street.
$7,500 or make me an offer. Open to trade offers, would love a 1999-2007 chevy truck and car trailer
On FN01RC (now on MB wheels)
Current Wheel Setup
On Square G8's (currently on MB wheels)
