Year: 2001
Make: Chevrolet
Model: Silverado 1500
Price: $14000
Mileage: 103000
Private or Dealer Listing: Private Listing
Location (State): MO
Color: Green
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
2001 Chevy Silverado Extended Cab 2wd has the 5.3L/T56 (6 Speed Manual) combo. Has 98k original miles on it and like 112k on the cluster. Still have original cluster to prove and less than a 4000 miles since the cluster swap. Cluster was swapped when truck was an automatic to have the factory trans temp gauge and the cluster can be swapped back for the original if owner prefers. Truck has all power options. Truck thousands of dollars in extra parts and only the best stuff was used. Cannot stress enough how solid this truck is and how well built it is!!!!!!!!!!!!! Listed below are things added to the truck that I can think of probably missing somethings. Truck has been dyno-tuned at Sho-Me Speed in Springfield, MO put down 442/440 @ 8 psi on the dyno. Truck is located near the Arkansas/Missouri Line. Asking $12,000 OBO, if interested can call/text Chris @ 479-five eight six-3732 Engine: 5.3L Vortec V8 Comp 275HR Cam PAC 1218 Springs Comp Magnum 7.4 Hardened Push Rods Procharger P1SC Currently Set @ 8-10 lbs of Boost Front Mount Intercooler 42 lb. Delphi Injectors Walbro 255 In-tank Fuel Pump LS1 E-Fans with Harness Stainless Long Tube Headers & Stainless Y-Pipe QTP Electric Cut-Out Borla ProXS Exhaust Smoothed & Painted Vortec 3 Piece Engine Covers Transmission: Tick Stage 2 T56 (6 Speed) Monster Stage 3 Clutch Monster Billet Steel Flywheel MGW Short Throw Shifter Suspension & Rear End: Full DJM 4/6 Lowering Kit & C-Notch Belltech Street & Performance Shocks Drilled and Slotted Rotors & Pads Russell Stainless Steel Brake Lines 4.88 Gears Yukon Duragrip LSD Perfect Launch Diff. Cover Caltrac Traction Bars Exterior: Fresh Paint Full HD Front End (Hood, Grille, Bumper Cap) All Colormatched (Bumpers, Mirrors, Handles) Bed has Shaved Stake Pockets & Molded Rollpan Shaved Tailgate Smoked 03-06 Silverado Tail Lights Clear Headlights/Parklights All LED Exterior Lights with Switchback LED in Turn Signals HID Hi/Lo/Fogs Billet Grille & Billet Emblem Tahoe 20s with New Tires Interior: Full Katzkin Leather Seats 03-06 Tahoe Center Console All LED Interior HD Cluster w/Trans Temp Gauge Autometer Wideband Gauge Autometer Fuel Pressure Gauge Autometer Boost Gauge Panasonic Double Din Stereo
