Could this be an optispark problem?
Old 11-21-2013, 02:56 AM
wolfen's Avatar
Default Could this be an optispark problem?
Lately I'll be driving on the freeway anywhere from 60 to 70 mph and all of a sudden I'll loose a little power and my rmp gauge will go to 0 rpms. If I tap the throttle pedal the rpms come back to normal and the car acts like nothing happened. A few times the car has turned off on me while on the freeway. Could this be an opti problem, or could it be a fuel problem?
Old 11-21-2013, 07:58 AM
Village Troll
SS RRR's Avatar
Could be an ignition switch problem.
Old 11-21-2013, 09:52 AM
bufmatmuslepants's Avatar
Check you battery connections are tight too.
Old 11-21-2013, 11:03 AM
Village Troll
SS RRR's Avatar
As well as the connections on the distribution block on the pass. fender.
Old 11-21-2013, 03:50 PM
davidc212k's Avatar
Are you getting a SES light? If so, scan for codes
Old 11-21-2013, 04:13 PM
wolfen's Avatar
The ses doesn't come on. I don't think its a power issue because the lights and everything else keeps running like normal, but I'll check all the connections anyway. It's weird the rpms go to 0 but oil pressure stays the same, battery voltage stays the same, and the car isn't over heating.
Old 11-22-2013, 12:20 AM
cardo0's Avatar
Could be. What year car u have? How many miles?
Old 11-22-2013, 04:50 AM
wolfen's Avatar
It's a 94 z28 with about 146xxx miles. I changed the opti about 2 years ago this one has about 25,000 miles on it.
Old 11-22-2013, 07:10 AM
Village Troll
SS RRR's Avatar
Opti's do not make a gauge cluster lose power or connectivity. Still think you may have an ignition switch problem.
Old 11-22-2013, 02:25 PM
dually681's Avatar
I agree w SS RRR
take all your keys off and only have the door and ignition on, no fancy heavy keychain either... =)
Old 11-22-2013, 06:47 PM
cardo0's Avatar
What brand opti? Drive though much rain where ever u are? Wash the engine lately?
Old 11-23-2013, 04:27 AM
wolfen's Avatar
It's not the cluster losing power, just the rpm gauge goes down to 0 rpms and the engine loses a little power everything else on the cluster works. The opti itself is a generic opti I got from a place by my house that rebuilds distributors, It's probably a rebuilt Oem opti. I live in Los Angeles so I don't really drive in rain. The car never gives me problems around the neighbor hood, just on the freeway. It almost feels like when I hold the throttle in a certain spot it happens. Could a bad throttle position sensor be causing this?
Old 11-23-2013, 09:13 AM
Village Troll
SS RRR's Avatar
If you think it's the opti, then replace it. Report results.
Old 11-23-2013, 10:04 AM
Man-Crush Warning
Shownomercy's Avatar
Its usually always the opti.
Rear end whine? Replace the opti.
Old 11-23-2013, 10:22 PM
cardo0's Avatar
Only the fastest ten bolts whine, make your rpms go to zero and kill your opti. How fast is your ten bolt car?
Old 11-24-2013, 10:13 AM
Village Troll
SS RRR's Avatar
What exactly did the doctors say was wrong with you?
Old 12-03-2013, 11:23 PM
cardo0's Avatar
Acute regurjentitous of nomercyderilicitous along with nonsensiblaberitous of my forumism.
He said to avoid technical discussion with idiots.
cardo
Old 12-04-2013, 07:31 AM
Village Troll
SS RRR's Avatar
More proof that California is the land full of fruits and nuts.
Old 12-04-2013, 06:11 PM
cardo0's Avatar
I have to go. Doctors orders.
Quick Reply: Could this be an optispark problem?
