Exhaust Manifold Double End Stud, correct size.
Old 11-21-2013, 10:07 AM
Mr.z/28's Avatar
Default Exhaust Manifold Double End Stud, correct size.
Im having trouble deciding which one is the correct size. I found two different size but no correct answer. First size is M8-1.25x25mm. The second M10-1.50x27mm. I drive a 2000 camaro z28. If someone has the right answer please let me know since some of the threads I came across on here were inconclusive. Thanks.
Old 11-21-2013, 11:12 AM
conan's Avatar
Are you looking for the studs that thread in to the exhaust manifold collector to bolt the catalytic converter up. Or the exhaust manifold to head studs ???
Old 11-21-2013, 11:22 AM
Mr.z/28's Avatar
Yes, the studs at the end of the catalytic converter to bolt onto y pipe.
Old 11-21-2013, 01:19 PM
conan's Avatar
M10 x 1.5
Total length of 65mm one side is 38mm and the side 27mm
Old 11-21-2013, 10:03 PM
Mr.z/28's Avatar
Thank you. I came across these at autozone. Total lenght is 62mm. Part # 03133. Can I use those?
Old 11-22-2013, 10:09 AM
conan's Avatar
Ya those should work just fine, I don't think the 3mm differance will be noticed.
Old 11-22-2013, 01:06 PM
Mr.z/28's Avatar
Thank you for your help. I appreciate it alot.
Cheers
Quick Reply: Exhaust Manifold Double End Stud, correct size.
