Is this belt routing ok?
The engine is a 2002 Lq4 6.0L with truck brackets on the Alt/PS Pump and a custom bracket for an R4 compressor on the top left with a rod end tensioner instead of a spring tensioner.
My main concern is whether or not it's "legal" to route the belt around the water pump before the crank pulley or if it "has" to come after. Seems like it won't be a problem.
I always recall reading 1/3 min contact of pulley for less chance of belt slip on acc.
your p/s pulley looks way to thin on contact %
might add a I-pulley in to the center below alt and above pulley for p/s to make belt get more contact on p/s pulley .
and were is your tensioner setup ?
Ya, you're direction is wrong, but just drawing the arrows the other way fixes that.
I don't think you'll have enough belt on the power steering pully. Are you creating your own set up or using something that's known good?
This one you started a few days ago...
