1988 Mustang LS turbo 7 sec street car
Year: 1988
Make: Ford
Model: Mustang
Price: $38000
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): MS
Color: Blue
LS Engine?: Car has LS engine
stock black interior, carpet and seats
full stock inside minus back seat
custom candy apple teal paint $6000
Weight 3380#
NHRA cer. 8.50 cage
Fuel System
Magnafuel 4703 pump plumbed in stock tank
-10 feed line
-8 return
areomotive fuel filter
weldon fuel pressure regulator
edelbrock pro flo XT fuel rails
220lb/hr fuel injectors
runs on e85 from pump
Engine
GM LS based RHS block 409ci
callies dragon slayer crank 3.819 stroke
GRP aluminum rods 6.115
CP pistons 4.130
Meziere eletric water pump
comp single roller timing chain
custom FTP/BTP solid roller cam
Trickflow 6 bolt 245cc heads
com 3/8-5/16 pushrods
crower stainless rocker arms
morel solid link bar lifters
felpro 6 bolt headgaskets
1/2" main head studs 3/8" secondary studs
9:8:1 compression
edelbrock pro flo intake
edelbrock 92mm throttle body
Turbo Kit
FTP custom stainless headers with SPD stainless collectors with v bands
T6 flange with pt-106 turbo
dual 46mm precision wastegates
50mm tial blow off valve
6 inch aluminum downpipe
Air to Air intercooler with 4 inch aluminum piping all v banded
drivetrain
PTC custom torque converter
Hughes Aluminum case pro mod glide all by PTC with hughes bell housing
8.8 rear end with full spool and 3.55s
Suspension
strange adjustable front shocks with coilovers
PA tubular k member
PA tubular a arms
upr caster camber plates
UPR double adj, lower control arms
UPR double adk. uppers with spherical bushings
stock springs
santhuff rear shocks
wheels/tires
weld v series 17x4.5 fronts with hoosier street series tires
weld RTS black rears with weld headlocks 15x9
MT pro drag radials
areospace brakes front and rear
electronics
Facotry GM computer
AEM oil pressure
AEM boost
AEM Air/Fuel
AEM trans temp
AEM oil temp
AMS 1000 boost controler with CO2
2 MSD two steps, one foot brake and one trans brake
boost leash pulse leash bump box
662-279-9052 text with any ?s or for any more pics
price is $38,000 obo
car is proven and fully streetable and i do not need to sell so no low ballers but price is obo and i will except trade offers but trade value will be higher, the car is a true street winner the past 2 years....
car has been best of 5.0@144 in the 1/8 and 8.0@170 1/4
on the 8.0 pass it was only on 17psi and left soft compared to most passes and only went 5.2 to the 1/8 because of bad track conditions. its tuned on 21psi and ive ran the car on 15-17 psi and never had it on 21psi, the car has even more potential as it is....
