Swap.... First start issues. Won't rev.
Old 11-24-2013, 08:02 PM
ridecats's Avatar
Default Swap.... First start issues. Won't rev.
I have 5.3 truck that is throwing a P1336 crank sensor not learned. And I can't not get it to rev past 1500 rpm. Trying to do the relearn with a Snap On tool/scanner and it needs to rev to 4000-5000 for the procedure to work.
No intake leaks
New sensors
50 psi at idle (60 at slight rev)
Cuts out hard when tring to rev really falls on its face
Any suggestions?
Have friend with Gm tech2 coming on Wednesday but I'm afraid I have some thing wrong other than the P1336 relearn code.
Thanks
Old 11-26-2013, 01:06 PM
gagliano7's Avatar
Do you lose fuel pressure when it cuts out?
Old 11-26-2013, 01:59 PM
406chvycamaro's Avatar
Is your computer getting a signal from the neutral safety switch? I've heard if you didn't run a neutral safety switch you couldn't perform a relearn
Old 11-26-2013, 08:51 PM
ridecats's Avatar
Pressure at 60 psi at very slight rev before it cuts out.
I'll look at the neutral switch.
Old 12-01-2013, 07:47 AM
ridecats's Avatar
Got it figured out. Was a grounding issue. I would have never though this was grounding.
Runs like a champ!
Attached Thumbnails Swap.... First start issues. Won't rev.-image-3978597302.jpg
Old 12-01-2013, 06:36 PM
rotor vs. piston's Avatar
Grounding issues, never more VVVVV
Quick Reply: Swap.... First start issues. Won't rev.
