5.3 gt45 turbo first 4 pass at 1/8 mile track
Old 11-25-2013, 06:02 AM
Hulkls1's Avatar
Default 5.3 gt45 turbo first 4 pass at 1/8 mile track
Car is a 2001 full weight a/c and all 3680#
5.3 gt45 18# boost 11 degrees of timing no meth yet
First pass 1.770 60 foot 6.84 at 106.95
Sec 1.700 60 foot 6.82 at 106.35. Stall up to 2500
3 1.56o 60 foot 6.60 at 106.56 stall to 3100
Old 11-25-2013, 07:18 AM
SPRAYED 01's Avatar
Nice job, you get the boost leash yet?
Old 11-25-2013, 07:42 AM
Hulkls1's Avatar
Got it but not put it on yet
Old 11-25-2013, 09:00 AM
AutoRoc's Avatar
Nice outing! Low 10's eazy! 9's are around the corner!
*Jealous....*
Old 11-25-2013, 10:00 AM
2muchboostNY's Avatar
Congrats! Any more detail on the build specs
Old 11-25-2013, 10:06 AM
Hulkls1's Avatar
Stock 5.3 zo6 cam 80# injector lol 8.8 rear end with stock 28 axles and a mini spool lol
Old 11-25-2013, 10:07 AM
Hulkls1's Avatar
On a good track I think I can get a high 6.30 out of it
Old 11-25-2013, 11:09 AM
Lol simple enough. Thanks again and amazing results for the simplicity. BTW which GT45? I see there are a bunch on ebay and a few companies that sell the GT45 like CX Racing.
Old 11-25-2013, 12:09 PM
Hulkls1's Avatar
EBay gt45 with these specs
Compressor Size: Inlet = 4 3/16", Inducer = 68.7MM, Exducer = 97.8 MM, Trim = 69,A/R = 0.66, Intake (ID / OD) = 2.25" / 3.25"
Turbine: Outlet = 4", Turbo flange = T4, Downpipe flange = 3.5" V-band, Inducer = 87.4 MM, Exducer = 77 MM,Trim = 92, A/R = 1.05 .
Old 11-25-2013, 01:10 PM
^^Thanks hulk. Impressive results with the 68mm version of this turbo. I have been looking at the new 80mm.
Old 11-25-2013, 09:57 PM
lsxmalibu's Avatar
What gear ratio.
Old 11-25-2013, 10:52 PM
SPRAYED 01's Avatar
I think the fuel rails made the biggest difference. Man that guy you bought them from must be so cool
Old 11-25-2013, 10:55 PM
Wicked69's Avatar
Nice outing. IT feels good the first time out and to mph that well, doesn't it? I know your timing is pretty low but becareful. 18 lbs of boost on pump gas and no meth is quiet a bit. Definitely get the meth on there before you turn it up, unless you are using E85.
Congrats man.
Old 11-25-2013, 11:25 PM
kelsey_canard's Avatar
Stout setup! I'm also running that same turbo. What are you shifting it at? Does it feel like its running out of steam at your boost level, or do you feel it has more in it?
Old 11-26-2013, 06:21 AM
Hulkls1's Avatar
Lol yea he helped me out a few times
Hulkls1's Avatar
Originally Posted by lsxmalibu
What gear ratio.
373 gear with 28" tire
Old 11-26-2013, 06:24 AM
Hulkls1's Avatar
Congrats man.
I had it on that night but it wouldn't work for some reason my iat was 76 at the end of my pass but it was 30 degrees out that night
Old 11-26-2013, 06:26 AM
Hulkls1's Avatar
When I max this turbo out I'm going to get the 80 gt45r or a pt88 lol
Old 11-26-2013, 07:16 AM
lsxmalibu's Avatar
if you had an l33 5.3 you could do the same times on 10 psi. maybe 12 your a little heavier than me. thats why i always say spend a little more you get a lot better motor,
Old 11-26-2013, 07:58 AM
Hulkls1's Avatar
I want a l33 bad lol I got this 5.3 for 160$ haha I'm going to find me a l33 first of the year
Quick Reply: 5.3 gt45 turbo first 4 pass at 1/8 mile track
