No pilot bearing??
Old 11-26-2013, 05:23 PM
Portcityls1's Avatar
Default No pilot bearing??
I took down my tranny on my 2000 trans am to do my clutch but there is no pilot bearing?
Old 11-26-2013, 05:26 PM
7camaro7's Avatar
be thankful!
I have broken two pilot bearing pullers and the third(blind hole puller) just does not get the job done.
Old 11-26-2013, 06:11 PM
BALLSS's Avatar
you need one or your input shaft bearings will die along with other issues.
Maybe someone did a clutch swap and did not put one in after removing.....for some reason
since there isn't one to remove....putting in one is EASY.
Old 11-26-2013, 06:34 PM
Ther is something else in ther but it's not a bearing. Is it possible a GTO tranny uses something else?
Old 11-26-2013, 08:16 PM
S10xGN's Avatar
Someone replaced it with a bushing....
Quick Reply: No pilot bearing??
