input shaft bearing race
Is this the #11 input shaft bearing race already in the input shaft? I bought it seperate, and am trying to identify what I still need to order. Also, On the adapter plate, is there two #5 shift rail bushings? one for each hole? Thank you.
So far I still need to order a shim kit, input shaft bearing race #8.
Anyone have a guide to setting preload? Thank you.
edit: Realized I forgot to upload the picture.
Looks like i'm just missing the shaft bearing race then. And the shims. I'm going to construct it without the race for now, to see if I am missing anything else. I believe it will be just as easy as pulling the midplate to add it. Then shims ect.
