old Muncie 4 sp to long crank block
Old 11-27-2013, 07:00 AM
forcd ind's Avatar
Default old Muncie 4 sp to long crank block
a buddy asked me about using an old Muncie 4 sp/bell housing on an LS engine
as near as I can tell from his desc. it may be a long crank block
has anyone done this conversion-what flywheel would you use-prob a hyd throw out bearing, and some kind of adapter pilot bushing
stock older gen 1 bell housing?
Old 11-27-2013, 08:44 AM
garys 68's Avatar
The Muncie is no problem. But as far as I know no flywheel that will work with a starter is available for the 99-00 long crank. Easier to get a short crank motor.
https://ls1tech.com/forums/conversio...-ls-motor.html
Old 11-27-2013, 11:18 AM
kodyowenby10's Avatar
the long crank was only 99-00 4.8 and 6.0 correct?
Old 11-28-2013, 06:04 AM
garys 68's Avatar
Yes, as far as I know.
Old 11-30-2013, 11:06 AM
Pocket's Avatar
Only the iron head 6.0's from 99-00
Quick Reply: old Muncie 4 sp to long crank block
