FS- Autometer Ultralite II gauges
Category: Accessories
Price: $525
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): NV
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
These gauges have not been modified from their factory configuration and can be used with any type of motor. I was using the VSS signal from my LT1 PCM for the speedo but you can use either that or any other speed sensor (if you are using a non electric trans). For the tach if using a non LS type, you can tap off of the coil, if you are going to use it in an LS type setup, you can to convert that signal to one the gauge can read (easy, do search on the inversion and hybrids section). The LS coil puts out a 4cyl signal I believe. If you have anymore questions, please let me know.
Here is a picture of them at night-
