How to modify stock transmission crossmember on Foxbody
ordered a AJE trans crossmember but it does not fit way too short the bushing need like 2 inches to fit. Was wondering how you all went about modifying the stock mustang member to fit. Any pictures will be really helpful. Thanks in advance. I am using a 4cylinder cross member
ended up using the stock one too and welded a piece on top with holes drilled. I did use the 4cyl that hos one hump so exhaust is going to be one tube or maybe i can still fabricate a dual exhaust.
