fuel pump wiring
Old 12-02-2013, 09:10 PM
5.slow99's Avatar
Default fuel pump wiring
i know its been asked many times so i apologize in advance but posting it again seemed easier. im running the dual walbro setup and have the sho me speed hotwire kit for the main pump. i want to run the second pump off the hobbs switch so my question is what is the most logical or simple way to wire the second pump? thanks for the help
Old 12-03-2013, 07:46 AM
Ollie8974's Avatar
Do a forum search, Keyword Hobbs switch.
Old 12-03-2013, 01:11 PM
Burken01's Avatar
Here I found it
Old 12-03-2013, 04:57 PM
jrpimp00's Avatar
^^ That's how I did mine
Old 12-03-2013, 08:30 PM
5.slow99's Avatar
even though i already have the hotwire kit for the main pump?
Old 12-06-2013, 04:21 AM
blow thru's Avatar
So with that diagram where its comes from pcm is that the original fuel pump trigger wire?
Old 12-07-2013, 03:13 PM
5.slow99's Avatar
the diagram above looks like if you were wiring two pumps without a hotwire kit correct? or am i just missing the point of this?
Old 12-09-2013, 02:18 AM
Burken01's Avatar
That would be a dual Hotwire kit shown above, as long as you use 10 gauge wire from the battery/alternator to the relay and to the pumps
If you already have the Hotwire kit installed..
Add a second fused power line from the battery to the relay
Take your relay and hook it up like this
30- 12v from battery/alternator
85- ground
86- Hobbs switch, other side of hobb switch to a "keyed" 12v source
87- fuel pump
So once you go into boost the Hobbs switch activated and powers the relay which then sends power to the fuel pump..
In the diagram I first posted has the Hobbs switch on the ground wire, which will work too.
You can put it on either or, you want the circuit to complete under boost and trigger the relay to fire the pump..
Quick Reply: fuel pump wiring
