Help ls6 clutch not disingaging
Had my t56 transmissions re built by TDP I installed a new ls6 clutch and slave myself... I have a stiff clutch pedal but the car is not engaging and disingaging when turned on. Would I need an adjustable master!? I took it to a shop after I gave up in it and they can't find the problem. Again my car is a 98 camaro. I'm hopping a master would fix the problem? Anyone have issues upgrading to the ls6 clutch?? These are the part numbers to the clutch C6LS7CLUTCHKI
12571611
24255748??
Any help is appreciated
12571611
24255748??
It is an ls7 clutch.. I replaced the slave from advanced auto.
I advised te mechanic I was still pulling out air with the mity vac. He said I had a stiff pedal. I honestly think he needs to make sure it's bleed right. How could I still be pulling air out. I did not bench bleed the slave but did pump 1xxxxxx times and used the mity vac for about a week straight
Could it be that air is getting into the system somewhere?
I had a similar issue when I installed a monster clutch, clutch wasn’t disengaging causing difficulty getting the car into gear while on, especially reverse. I tried to bleed bleed and bleed some more, even replaced the mc and slave again.
My fix: I pulled the trans and looked at the plate fingers, they were uneven due to not properly torquing them down. I torque'd them down, reinstalled the trans and its been working properly ever since
