Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Stumped by high idle while moving
Old 12-05-2013, 08:14 PM
Fweasel's Avatar
Default Stumped by high idle while moving
Within the last month, my car has developed an idle issue that only presents itself when the car is in neutral and I'm coasting towards a stop light. I clutch in, revs drop to about 1,600 RPM, and hold there steady until the car stops rolling. The second the car stop rolling, the revs fall to ~850RPM and hold steady. Clutch in or out doesn't seem to matter, exhibits the same symptom, plus, cruise control works so I don't suspect the clutch position sensor. I performed the throttle body relearn procedure several times, reset the ECM, no change.
It doesn't happen every time, but it does happen a majority of the time. Trouble has shown up about the same time the ambient temp started to drop, but we've had several warm days and the problem still persisted. From time to time I also feel a lack of engine breaking when off throttle, but still in gear. I suspect the engine is still being fed power (high idle point) and as a result is not slowing the drivetrain down like you would normally expect. The only similar complaints that I've found in old threads seem to be caused by dragging clutches, or a bad idle all around. Nothing quite like I'm experiencing. Any ideas?
Old 12-05-2013, 10:04 PM
demang's Avatar
Do you have a tune?
Old 12-06-2013, 07:30 AM
Fweasel's Avatar
Originally Posted by demang
Do you have a tune?
Good question, I should have addressed that. No, I do not have a tune. Stock manifolds, cats, and catback at this time.
Old 12-06-2013, 08:23 AM
Stone17's Avatar
Maybe check for intake leaks. I have a problem where my K&N tube will discount from the TB and make my car idle high coming off the freeway.
Old 12-06-2013, 02:53 PM
MichaelSuch's Avatar
High idle like this is usually due to some kind of vacuum leak post MAF. Check all the vacuum lines, make sure clamps are tight on the intake tube after MAF. You can use starter fluid and spray where the gaskets are, connections, intake manifold, throttle body, etc.. to help pinpoint where the leak is. If starter fluid gets in the combustion chamber the idle will smoothen out and you'll know where the problem is.
Old 12-24-2013, 12:28 PM
Anarchy999's Avatar
Did you ever get this resolved? Mine does this as well, hits about the same RPM as yours and then back down when I stop.
Old 12-24-2013, 07:45 PM
punishmentcycle's Avatar
You have a broken motor mount bro.. More than likely drivers side. Ask me how I know lol
Old 12-25-2013, 01:19 PM
Fweasel's Avatar
no, not yet. Too much time wrapped up in getting the car ready for the audio install over Christmas to troubleshoot anything else. My guess is a vac leak, and when I have the time, I plan on spraying starting fluid around the intake track and listening for idle changes.
Old 01-02-2014, 07:51 PM
spearfish25's Avatar
Every manual transmission car I've had does this. It's something with the ECU and emissions control. Not a vacuum leak.
Old 01-03-2014, 05:11 PM
Anarchy999's Avatar
Yes it can be a vacuum leak and that high of an RPM is not normal with every manual transmission. It should be able to be tuned out if it is not a leak.
Old 01-13-2014, 04:01 PM
Fweasel's Avatar
Update to my original issue. The car sat at my audio installer's shop for nearly a month over the Christmas and new years break. The battery died and was recharged, the car also spent a fair amount of time with all power disconnected. I eventually had them install a new Optima Yellow top. Since getting the car back, the high idle issue is gone and the RPM's behave normally when I coast to a stop.
Weird.
Update II:
The hanging idle issue returned a few days after the battery swap. I had a spare MAF sensor on hand, swapped it, and have not had the issue since. My original MAF was causing the problem.
Quick Reply: Stumped by high idle while moving
