347/317/ON3 76/E85/16psi=758rwhp/744rwtq
We did not build this, I just specified the camshaft and assisted in some parts purchases. Nice little car! Here are some details that I have:
-LS1 block
-Stock Crank
-Wiseco pistons
-Eagle Rods
-Stock 317's
-10:1 compression
-ON3 Ceramic Ball Bearing 76mm turbo (74mm turbine .96 AR)
-16psi
-LS6 intake
-Custom Tick Performance turbo cam 226/238 .605"/.585" 116lsa (zero degrees overlap)
-T56 trans
-A2A intercooler
-18* timing on E85
Full boost by 3500rpm with this turbo and cam combination. Makes for a very fun street car that will hold it's own at the track as well.
-LS1 block
-Stock Crank
-Wiseco pistons
-Eagle Rods
-Stock 317's
-10:1 compression
-16psi
-LS6 intake
-T56 trans
-A2A intercooler
-18* timing on E85
http://www.ebay.com/itm/On3-Performance-76mm-Ceramic-Ball-Bearing-Turbocharger-/141130686520?pt=Race_Car_Parts&hash=item20dc0b6038
It was just dyno tuned and all the tracks in SC/NC are closed.
I'd say so, but remember different turbochargers will move different amounts of air flow even at identical boost levels. He's on E85 and has a lot more timing in his than you do.
Yes, it has head and main studs.
