Bob's 77 C-10 Stepside
Old 12-07-2013, 06:43 AM
99VetteFRC's Avatar
Default Bob's 77 C-10 Stepside
I have been doing this swap for a couple months now. I met Bob at Hunt Valley Horsepower and during conversation he told me about this truck he had and how bad the gas milage was. After I showed him my Chevelle we decided to put the LS/4L60E in the truck. Here is the truck when dropped at my house. Complete and running with the new engine wrapped in the back. I had Bob get the engine and trans from Bow Auto in New Hampshire from Ebay. This is the same placeI got my engine from.
Old 12-07-2013, 06:51 AM
99VetteFRC's Avatar
Bob's 77 C-10 Stepside-dscn1778.jpgI labelled all the harness connectors and took it work and rewired on down time.
2006 4.8L/4L60E out of a cargo van. In 06 the vans still use DBC TB.
Using a Walbro 255 inline pump and a Corvette filter.
1" setback motor mount adapter plates. Picked up off Ebay.
Click image for larger version
Old 12-07-2013, 07:01 AM
99VetteFRC's Avatar
Got the engine and trans out!
The truck manifolds that came with the engine wouldn't fit between the frame rails without some clearancing. I had these F-body manifolds laying around and they fit well.
With the trans in the and the motor mount adapter selection, I got lucky and the driveshaft went right in and didn't have to be cut. I unbolted the crossmember and moved it back and drilled a couple holes and bolted it in.
Old 12-07-2013, 07:10 AM
99VetteFRC's Avatar
The column shifter linkage fit perfectly with no adjustment.
I aquired these Yukon engine covers to dress it up. Yeah I know it says 6000, But I figured whet the hell.
This is going to be where the PCM is going to be mounted.
I didn't have the flanges for the F-body manifolds so I cut them off and welded some pipe to the ends.
Attached Thumbnails Bob's 77 C-10 Stepside-dscn1798.jpg   Bob's 77 C-10 Stepside-dscn1800.jpg
Old 12-07-2013, 07:20 AM
99VetteFRC's Avatar
I was trying to figure out a way to mount the PCM and came up with this. I made it out of a piece of 3/4" angle and 3/8" tubing. I then welded four 1/4" x 1" bolts to the corners for mounting studs.
I just bolted it to the four bolts that hold the PCM together.
The SBC radiator has one of the heater hoses routed to it so instead of blocking it off I made an adapter to connect the steam tube to it. I took the heater hose nipple out of the SBC and pressed a fitting into it that had a 1/8" pipe thread then welded them together. I put a brass 1/4" nipple into the adapter and connected the hoses.
Old 12-07-2013, 07:26 AM
99VetteFRC's Avatar
This truck has factory guages in the dash. It uses a mechanical oil pressure guage. I just hooked the SBC oil pressure line to the bypass adapter on the side of the oil pan. The factory temp guage works with a sensor I picked up from a member from this forum.
Old 12-08-2013, 12:44 PM
99VetteFRC's Avatar
Short movie I made.
Old 12-17-2013, 11:07 AM
99VetteFRC's Avatar
Here a few pics of the Holley a/c bracket and the GM radial r4 comressor we are going to use. Very nice setup.
Nice pic of the truck sitting in my shop.
Old 12-18-2013, 12:10 PM
99VetteFRC's Avatar
Here are the last pics of Bob's C10. It is finished. A/C works great and an Ebay CAI for an 05 Silverado Finishes the swap. I hope everyone has enjoyed.
Old 12-18-2013, 12:59 PM
ijimmy's Avatar
expound on that temp sensor
Old 12-18-2013, 07:14 PM
99VetteFRC's Avatar
I bought it from a member on this forum. He told me it was from Dakota Digital. It screwed directly into the head, I put it in the passenger side, and had the same connector end that the factory old school sensor had so I didn't have to modify. It works perfectly.
Old 01-01-2014, 09:09 AM
99VetteFRC's Avatar
Here i a link to the next LS swap I'm working on.
https://ls1tech.com/forums/conversio...ls1-4l60e.html
Old 01-01-2014, 07:19 PM
71monte-carlo's Avatar
Overall how much did it cost to do this swap. Looking to do the same to my 2nd 71 Monte. Just don't have time to do it myself
Old 01-02-2014, 06:19 AM
99VetteFRC's Avatar
I charged him $1500.00 for the labor. Engine and trans prices vary, but I think he has about $3300 in the whole thing. Would have been several hundred cheaper but he wanted A/C. Holley bracket, compressor and modified hoses cost close to $500 I think.
Old 01-02-2014, 08:16 AM
OK I definitely would like for u to do my next swap for me, I'm pretty sure. Just gotta figure out a way to get my car to PA
From Mich
Old 01-03-2014, 08:20 AM
chevelleluvr's Avatar
Im doing this same swap but in the pic with everything completed it shows the wiring for the a/c compressor, is that the factory wiring or does that go into the pcm??
Old 01-05-2014, 03:43 PM
99VetteFRC's Avatar
I used the factory truck wiring on the A/C. Made it simpler.
Old 01-05-2014, 03:49 PM
99VetteFRC's Avatar
From Mich
You can put it on a trailer and spend the weekend driving it to me. Might be able to meet half way. I would need half the money paypal to me ahead of time. You supply the parts and they can be shipped to me. If you really want me to do this for you PM me and I will discuss it.
Quick Reply: Bob's 77 C-10 Stepside
