Is my carb going to be too small?
My boss was gracious enough to give me a like new 670 CFM Holley street avenger carb. From what I'm reading a 750 would be ideal.
My setup
2800lb fox mustang
Lc9 5.3 with 241 heads
Comp thumpr cam
2600stall
Hedman hustler headers 2.25' dual exhaust
Performer rpm intake
3.55ish gears (to be decided later)
My setup
2800lb fox mustang
Comp thumpr cam
2600stall
Not at all. Do some research on the 670 avenger carb and I bet you'll find it will work. Just make sure to get the internals setup for your needs. You might find that it will be lean or rich and need tuned.
