54CC heads and STOCK short block (COMPRESSION???)
Old 05-08-2004, 04:05 PM
sr71bb's Avatar
Default 54CC heads and STOCK short block (COMPRESSION???)
Need to get a streetable compression using 54CC heads and STOCK bottom end. I calculate 12.3 to 1 compression using stock gaskits. The probably WON'T work on 93 octane and it needs to. If I use .087 gaskit what would compression be???? ANybody with any better suggestions????
Old 05-08-2004, 05:10 PM
7 Second Club
Phil99vette's Avatar
You can get that combo to work with a big and with alot of overlap and no advance ground in....Make sure your combustion chambers have been finished.
Phillip
Old 05-08-2004, 09:03 PM
jrp
SN95 Director
jrp's Avatar
http://www.rosspistons.com/calculator.php
Quick Reply: 54CC heads and STOCK short block (COMPRESSION???)
