MSD 6012 timing?
Do you have the software loaded on a laptop? Do that and get it to communicate with the box by plugging the laptop into the box..
Plug the #1 chip in the box and this will give you a base line to start with and adjust a few simple things from there. Keep the timing around 28-36 degree's. Rev hi is your rev limiter keep it around 7500 for now.
unless ur using a map u need to zero out those tables on the map chart. something they dont tell u. ive had my car from 28 to 36 deg total time but runs best at 32. Just make laps n log the results shell tell u what she wants lol
Old School Heavy
I always hate to see guys get timing advice when they have not even shared the details of their build. I also hate to see people start out with their testing at higher total timing settings. Too little timing within reason will not get you in trouble, but too much timing can do some damage.
Do a search in this section for timing threads. There are many great discussions on this topic to learn from including a sticky that could probably be re-titled to include 6012 users.
bad 6012 box
Have any of you had a 6012 box go bad on you? MSD. says they have no problem with them. I am on the 3rd one in my car that only has a couple hours run time on it.
Only negative things I've heard about the 6012 ended up being user error. But then again, so were most all of them. Check, Check, and Recheck your grounds. Then when your done with that. Check and make sure you have at least 12 volts.
2008 5.3 bored to 3.903, ported & polished 243 heads, brian tooley valve springs, edelbrock performer RPM intake with a holley 750 double pumper, comp cam valve lift 0.553/0.556 109* lobe separation, t56 with 3.73 gears.
Really wish someone would poste a guide how to tinker with the msd software, really don't want to mess it up, thanks guys
what do you guys think a good timing curve would be? from idle to at least 6500 RPM
Also do i need a map sensor? some say yes, and some no, what are the benefits to a map sensor, I do not have any boost or any sort, just engine, thanks
I have a MAP but only use it to read vacuum, does nothing to my timing. Just be sure to zero it out in program even if it's not hooked up.
MAP will give better MPG's when cruising is all.
