lq9 88 iroc part out
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): MD
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block
LS Engine?: Fits LS Engine
I have a 1988 Camaro iroc-z T-tops shell I was planning to do a lsx twin turbo swap to it
I have a lq9 block bored 30 over $400 sold
forged eagle crank with 4" stroke $800
forged eagle rods rod bolts rated for 1250hp $550
forged custom made low compression diamond pistions $600
$1500 takes the whole rotating assembly
ls6 intake with 92mm tb $350 sold
l98 oil pan and pick up tubes $100
melling high pressure oil pump $100 sold
motor mounts $100
vally cover and gasket $20
front and back motor covers $30
ls1 harness and ecu $150 sold
alt, water pump, power steering pump 40,000 miles $150 sold
trans cooler $20 7" tac with shift light $40 sold 3" xpipe and cherry bomb mufflers $80
cable to move the battery to the back $15
bmr suspension
Part #: XSB001 Xtreme Anti-roll Kit, $410
Part #: PHR004 Panhard Rod Relocation Kit, $180 sold
Part #: TCA004 Lower Control Arms, $210 sold
Part #: SFC008 Subframe Connectors, $180 sold
Part #: STB004 Strut Tower Brace, $160
Part #: MPHR002 Panhard Rod, Chrome Moly, $140 sold
after market wing 3ed gen wing $60
after market 3ed gen hood $400
I have about ten tubs of extra parts no idea what all is in them, have extra ttops, im sure there is other things too the more you buy the better price ill do
Price for the set of rods?
Price for set of pistons?
I have a 1988 Camaro iroc-z T-tops shell I was planning to do a lsx twin turbo swap to it I have a lq9 block bored 30 over, forged eagle crank with 4", stroke forged eagle rods, forged custom made low compression diamond pistions, ls6 intake with 92mm tb, l98 oil pan and pick up tubes with melling pressure oil pump, motor mounts, vally and front and back motor covers, ls1 harness and ecu, alt, water pump, power steering pump, trans cooler, 7" tac with shift light, 3" xpipe and mufflers, cable to move the battery to the back, bmr suspension
currie enterprises 9" rear with 3.73 gears, comes with rs and iroc-z rims, factory and after market wing, after market hood, I have about ten tubs of extra parts no idea what all is in them, have extra ttops, im sure there is other things too
