What upgraded T56 part causes notchy shifting?
Years ago on my last T56 upgrade I bought some aftermarket parts from a sponsor which since went out of business. For 1-2 and 3-4 gears, I purchased upgraded parts which were advertised to make it more reliable in the long run, but would be less friendly to speed shifting. I can't find the receipt, and that behavior is starting to annoy me. To which parts do I need to revert?
Mike
....could be hydraulics. Aftermarket MC has often resolved...many like the Tick. I have the McLeod (Wilwood)
maybe this:
http://www.superchevy.com/technical/...ssion_rebuild/
As the vice president of the remanufacturing division at Rockland Standard Gear, George Kreppein Jr. showed us all the tricks that he had up both of his sleeves and didn't hesitate to tell us what works and what doesn't. Case in point: He wholeheartedly recommends carbon-fiber OE synchronizers and billet synchro keys with a steel shift fork on the commonly weak 3-4 gearset, but finds no value in bronze fork pads. He explained that the nylon OEM-style fork pads work very well and that the metallic units just beat up and wear the slider grooves unnecessarily.
^apparently keys from thegearbox aren't so sweet...
https://ls1tech.com/forums/manual-tr...6-rebuild.html
