FS: New GT45/Y2004k turbo
Category: Engine - Power Adders
Price: $1
Location (State): CA
Item Condition: Brand New
LS Engine?: Fits LS Engine
Only used for mock up, never ran.
SOLD
Info on the turbo
The GT-45 Turbocharger is a larger turbo capable of generating 1000+ hp, depending on application and with the correct tuning. The GT-45 can handle a peak boost of 25-35 psi. The GT-45 is generally used for larger displacement engines of 3.0L and up, since these types of engines can produce enough exhaust volume to push the GT-45.
Compressor Size: Inlet = 4 3/16", Inducer = 68.7MM, Exducer = 97.8 MM, Trim = 69,A/R = 0.66, Intake (ID / OD) = 2.25" / 3.25"
Turbine: Outlet = 4", Turbo flange = T4, Downpipe flange = 3.5" V-band, Inducer = 87.4 MM, Exducer = 77 MM,Trim = 92, A/R = 1.05
