Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
V1 with aa corvette brackets?
Old 12-12-2013, 05:05 PM
b20forlife's Avatar
Default V1 with aa corvette brackets?
Hi I was wondering if I switch over my accessories over to vett accessories will the a&a supercharger brackets work? How hard would it be to make the accessories fit? I can build all the intercooler pipping just need the brackets. Anyone have some info on this? Thanks
Old 12-12-2013, 05:51 PM
CTS-V Shifter Sales
07CTS-V's Avatar
I seem to recall an issue with the alternator hitting the fuse box when relocated to the passenger side.
Old 12-12-2013, 05:59 PM
omar2guy's Avatar
If you do, ill take ur stock accessories but for real keep me in mind if you do
Old 12-12-2013, 08:11 PM
serik21's Avatar
If you wait a month I can let you know for sure how it clears. As I have the aa brackets for procharger just to slammed with work to take the car apart and install everything.
Old 12-13-2013, 03:32 AM
b20forlife's Avatar
Ok sounds good. Hopefully it all fits properly. You using the cts-v accessories?
Old 12-13-2013, 07:36 AM
serik21's Avatar
Thats the plan. Cts-v shares the same spacing as the corvette on the accessories
Old 12-14-2013, 10:28 AM
Steve01SS's Avatar
The A&A bracket bolts to the water pump (2 bolts where the tensioner go) and to the head on the passenger side.
You "may" need the LS2 C6 version of the bracket. The reason being the water pump. All V1's 04-07 and the LS2 C6 corvette share the same water pump. A&A has told me that the C6 water pump requires the C6 version of the A&A bracket. Also if you have an 06-07 V with the 90mm TB, it will not clear the C5 bracket. The TB motor will hit unless you flip the TB.
The alternator is not relocated to the passenger side. It stays on the driver side. On a C5/C6 it is on top, and the V is on the bottom. This should not cause a problem though since the blower is on the pass side. The passenger side of the motor is the same, so I wouldn't see why it would not bolt up with the LS2 C6 bracket. I don't know how well the blower will clear though. Might have to move a few things around. There is more clearance on a corvette. The accessories on the driver side should have no effect on mounting.
I have experience with the A&A setups and they are very well built. No experience trying to put one on a V, but done a couple C5/C6. Josh over at A&A is a really good guy to deal with for questions or parts.
I'd really like to see this done. Might be a better option than the Maggie on these cars for people who can fabricate the piping and etc.
Old 12-14-2013, 11:19 AM
shadyLS6's Avatar
yup all standard
i took this picture a while back of a guy in Florida's setup. 383 forged ls6, great setup, the thread is on the Cadillac fourms
Old 12-15-2013, 02:50 PM
1BADCTS's Avatar
This looks like you would have much better air filtration options than the GTO bracket, and it looks like he may have reused the stock fans, or at least used pullers which gives you a lot better intercooler clearance behind the bumper!
Must be a custom radiator though given how low it is, and the piping.
Quick Reply: V1 with aa corvette brackets?
