LQ4 370 Kytp build
Old 12-12-2013, 10:19 PM
wes96z's Avatar
Default LQ4 370 Kytp build
So I have been piecing this project together for the last 4 years I finally got all the parts I needed and figured I'd share the build as I go.
Car is a 2000 z28 previous set up was a forged ls1 cam and spray it ran well but I hated dealing with nitrous always running out and was seeing alot of folks making big power from there turbo set ups so i decided to take the plunge. I pulled my old motor sold everthing and started from scratch. below is what's going in it.
HKE LQ4 370 stock crank, Callies compstar rods Diamond pistons, ARP everything, Morrell lifters, ETP 225 heads Harland sharp rockers, custom specd turbo cam by Ed Curtis at flow tech
Spec Twin Disc Clutch
Nasty stage 3 fuel system twin intake pumps, Magna Fuel Billet boost reference regulator 8an feed 6an return steel braided lines, 60lb injectors, custom rails
Kytp truck manifold kit, Turbonetics TC76mm, Tial waste gate, JGS blowoff valve, Hot side coated by jet hot, BMR turbo k-member
E boost 2 controller
Pulled the front clip off and mounted the FMIC[URL=http://s929.photobucket.com/user/wes96z/media/image-13.jpg.html][/URL
Old 12-12-2013, 10:22 PM
wes96z's Avatar
I've got lots of pics anybody know how to post them directly to thread not thumbnail style also the thumbnail only lets me do one pic per post???
Old 12-13-2013, 03:26 AM
sbcgenII's Avatar
[img]www.addressofyourpicture.com[/img] paste the link of the picture you want to post then put [img] in front of the link and [/img] at the end of the link.
Old 12-13-2013, 10:24 AM
SPRAYED 01's Avatar
What turbo?
Old 12-13-2013, 04:40 PM
wes96z's Avatar
Originally Posted by SPRAYED 01
What turbo?
Turbonetcs TC76
Old 12-13-2013, 05:16 PM
supersick99z's Avatar
Would be interested in more pics. Have a KYTP kit in the garage to install if I ever get around to it
Old 12-14-2013, 12:22 AM
coolmanvette75's Avatar
Originally Posted by wes96z
Turbonetcs TC76
All that work and nice parts just to use a TC76? C'mon man throw a real turbo on there!
Old 12-14-2013, 12:16 PM
SPRAYED 01's Avatar
I ran a tc78 (basically the same) it was done at 5200 on a 348. Go with a tc 75/76
Old 12-14-2013, 05:33 PM
wes96z's Avatar
I liked the look and extra space of moving the radiator up so I started hacking the front support
Old 12-14-2013, 05:35 PM
wes96z's Avatar
Haha I'll see how this one runs since I have it but I may upgrade later
Old 12-14-2013, 05:38 PM
JAX04's Avatar
photobucket is your friend
wes96z's Avatar
Got it all boxed in
Old 12-14-2013, 05:42 PM
wes96z's Avatar
All I have is an I pad photobucket is having issues uploading my pics
Old 12-14-2013, 06:00 PM
wes96z's Avatar
Primed and painted
Old 12-14-2013, 06:02 PM
wes96z's Avatar
Old 12-14-2013, 06:07 PM
wes96z's Avatar
So I bought the Griffin that everybody else has and got some dual flex a lite fans I had to figure out how to mount them I wanted it to look clean and seal well against the radiator. So we ended up tigging a small frame with mounting tabs onto the radiator and mounted the fans big props to my buddy Ben at Evil Arc Fabrications for his help. I think it came out really nice
Old 12-14-2013, 07:42 PM
wes96z's Avatar
Motor mounted and all the accessories on hot side bolted up
Old 12-14-2013, 08:27 PM
wes96z's Avatar
Working on installing and routing the fuel system and brake lines
Old 12-14-2013, 08:30 PM
wes96z's Avatar
Old 12-14-2013, 08:49 PM
wes96z's Avatar
Time to stab the motor in
Quick Reply: LQ4 370 Kytp build
