Power requirements for the MSD 6ls-2
I've read the paper and the iPhone app's instructions and I've noticed that msd omitted the very important part about the power requirements needed for this unit. IE how many amps does it need to be fused for.
I plan to power it directly from the battery switched with a relay.
Also while I have you here can you direct me on identifying the ls1 vs ls2 style coil.
LS2 coils give a significantly hotter spark than the LS1 coils do. I'm not sure what the MSD box does differently when you select one over the other
Coil pacs are easy to identify, google is your friend
https://ls1tech.com/forums/lt1-lt4-m...selection.html
As for power, you are right, they don't mention what sort of power draw and as far as I know you are the first person to ask. Like Zones said just take it off a switched 12V source. Some people try to reuse the old ignition coil wire. You can do that if you make sure to bypass the ballast resistor. Been more than a few guys who had trouble from that mistake.
MSD boxes should not exceed 1.2 amps per 1000 RPM.
You can pull 12V off the starter if you have no other source.
You can pull a line off the starter to a lug mounted on the fire wall as a general 12 source. Many people mount their MSD box in the area of the glove box, you should be able to find a source there.
