Cam identification help
Old 12-14-2013, 12:57 PM
shoeboxvette's Avatar
Default Cam identification help
Need help Identifying s cam. Motor is an LQ4 with some external swap parts. Fbody pan aftermarket pulley system BLUE behive springs, no information available on mods from seller! Looking through valley cover you can see the front and rear lobes of cam which appears to be new, Got cam pulled there are stamped numbers on the back of cam 8753 between 1 and 2 lobes 411911 and between 7 and 8 lobes 1 1E I 096 if anyone can help it would be appreciated
Old 12-15-2013, 11:52 AM
Ok, Then lets start off with what it's not. whats the stock LQ4 Cam markings or stamped numbers look like.
Old 12-15-2013, 02:17 PM
i r teh noobz's Avatar
I can't find any combination of those part numbers in Google. Its likely an aftermarket cam. A machine shop may be able to measure lift and duration for you, or you could attempt to do so yourself with a degree wheel and a dial indicator.
Old 12-15-2013, 04:29 PM
Thanks,
I've spent a couple of hours trying to search everything I could think of was hoping that someone would recognize a marking or # of some sort. I'll Email some of the cam manufacturers and see if I have any luck.
Old 12-16-2013, 11:44 AM
Anybody???
Old 12-16-2013, 02:35 PM
LS1Tech Sponsor
hellbents10's Avatar
We have a cam measuring machine, I can give you a full cam card report on it. Let me know LS1tech members get a special rate.
Quick Reply: Cam identification help
