MWC 9'' and 4 channel TCS/ABS
is there anyone with full ABS/TCS running a 9'' with no issues? After a search there is only 1 thread where someone ran into problems, I am trying to make a decision on rear end this week and looking for feedback.
I have had my MWC w/4 channel for almost 4 years now and never had a problem. traction and ABS works just like they did with the stock 10 bolt. I drive my Camaro in all weather conditions. If i did it again, i would probably drop the TCS cause I dont drive the car as much anymore, but I do not consider it a weak point. never had an issue.
LS1Tech Premium Sponsor
The 4ch system is very sensitive, but we usually don't have any problems with it. If you have the need for retaining it then it is worth doing, but chances are most people have never had the need/used for the abs system or the traction control system. There's not a lot to it, but it only takes one little thing like a intermittent/poor connection that looks fine to the eyes, slight runout in the reluctor to sensor clearance, sensor resistance out of spec, etc.
I have seen Moser, Strange, and other rears have issues with the 4ch systems as well. Like I said, not too often, but not impossible.
Thanks for the feedback guys. I am trying to decide on the S60 or MWC 9''... Noise and Function are high on the priority list. I didn't have any issues with my old S60 but I wanted to try something new with this one.
I WANT to retain ABS/TCS since my Wife will drive the car too.
Give us a call. We can go over your needs and put you in the correct rear end. We have guaranteed lowest prices on all of your needs. We can also answer any questions you have about the ABS and 4ch. We are open everyday from 8am-5pm. Monday-Friday.
