lil fox help please.
Old 12-16-2013, 01:23 AM
Swapper's Avatar
Default lil fox help please.
alright so i got my motor fired up but i need to finish up connecting it to the car through the ignition switch. when i pulled the motor i pulled all the harness and coil and all. i do have that one round grey connector that sits by the drivers side shock tower.
anyways im tryin to figure out how to get power to my ignition siwtch/ fuse block and all that good stuff so the car side of things will work again.
i ran power to the ignition switch but its almost like i lost a ground somewhere since that harness/ pcm got removed.
any help will be greatly appreciated. thanx!
i have found some diagrams but am a little bit lost.
Old 12-16-2013, 05:45 AM
krochus's Avatar
Will the engine turn over on the switch?
If not did you "jump" across the neutral start switch?
Old 12-16-2013, 09:08 AM
zipster's Avatar
If you removed the starter solenoid, there are a couple of wires that are connected to the battery side. They feed the fuse box, power windows, and such. They need to be connected to power the car.
Old 12-16-2013, 09:58 AM
Swapper's Avatar
I tied the white/red and red/blue (I think that was the colors) together under the carpet.
Zipster, do you know which wires?
Old 12-16-2013, 10:49 AM
zipster's Avatar
Should be a thick yellow wire, it was connected to the starter solenoid on the drivers side fender.
Old 12-16-2013, 11:59 AM
Swapper's Avatar
I tried ruining peer to the yellow wire off the ignition switch and got nothing
Old 12-16-2013, 03:25 PM
zipster's Avatar
What other wires did you remove from the starter solenoid? Also was your car a 4 or 8 cylinder originally?
Old 12-16-2013, 03:28 PM
zipster's Avatar
Also, there is a group of ground wires on the front of the drivers side strut tower. They need to be grounded.
Old 12-16-2013, 07:42 PM
Swapper's Avatar
car was a 4cyl auto.
pretty much all the engine bay wiring is gone. the starter solenoid, engine harness and ecm.
i have the headlight harness and this plug and thats about it forward of the firewall.
Old 12-16-2013, 09:20 PM
zipster's Avatar
Where in the engine compartment is that grey plug? Can you give me the colors of the wires?
Old 12-16-2013, 09:26 PM
Swapper's Avatar
It was right next to the divers shock tower. I will try and get you the colors here soon.
Old 12-16-2013, 09:34 PM
zipster's Avatar
Is it in front or behind the shock tower?
Old 12-16-2013, 09:36 PM
zipster's Avatar
Is that pic looking up in the drivers side shock tower?
Old 12-16-2013, 10:29 PM
Swapper's Avatar
looks like it was right next to the master cylinder. in the pic i posted up there that is looking up at the shock tower. hiding wire harnesses.
oh and in no particular order heres the colors from that plug.
red/green
orange/black
black/yellow
red/blue
black/yellow
red/white
green/purple
white/pink
looks like thats the plug. top right between the reservoir cap and strut mount.
looking at this pic i think i see some wires i might need. i think i cut and capped them and taped them up inside that harness i tucked away.
Old 12-16-2013, 10:37 PM
usdmholden's Avatar
If you want I can look at my car tomorrow night and tell you where it goes in mine. I have a 1991 2.3L T5 car. I'm pretty sure it went to the engine harness or the EDIS but I can't remember. I have not pulled any wiring out of my car yet because I plan to run the OEM temp, oil pressure, coolant, and fuel level gauges, so I need some of the engine harness wiring.
Old 12-16-2013, 11:10 PM
Swapper's Avatar
usdmholden. hey if you dont mind that would be cool.
ive done swaps before and usually its like just find the right wires either off the ignition switch or fuse block and you get power again but this thing for some reason has me lost. lol
Old 12-17-2013, 12:16 AM
BigEd_72455's Avatar
Dammit man, you have GOT to learn to resize a picture before posting it up!!!
That sumbeech is 2 pages wide on my 19" monitor!!
Old 12-17-2013, 12:22 AM
Swapper's Avatar
yeah i dunno why theyre soo big. on my build thread they come out normal size.
Old 12-17-2013, 06:14 AM
krochus's Avatar
If you'd quit drinking that nasty Shasta cola it'd help ;-)
I've got a pic of my solenoid pre tear down I will try to upload and post
Old 12-17-2013, 09:08 AM
Swapper's Avatar
Lol gotta drink the Shasta.saves money to but parts.
Quick Reply: lil fox help please.
