built 4l60/tci 3600
built 4l60/tci 3600
Category: Accessories
Price: $1700
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): OK
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Trans list- 1700+shipping. 405-343-1272
Raybestos Stage 3 FrictionsComplete steel module with .097" thick 3-4 kolene steelsNew 28 Element Input SpragNew ACDelco Upgraded Complete Pump AssemblyNew Hardened Pump RingsNew 13 Vane Pump RotorHigh Performance Factory .500 Boost ValveBushing KitNew Thrust WashersComplete Torrington Bearing KitHeavy Duty Hardened "Beast" Sun ShellReinforcement sleeve to strengthen input drumNew ACDelco 5 pinion planetaries both front input and rear reactionNew Low/ Rev Heavy Duty Spring and RollerCorvette ServoAll aluminum accumulator pistonsWide Carbon-Fiber 2-4 Band with heavy duty anchorsNew ACDelco reverse input drumNew updated performance valve body separator plate w/ Torlon check ballsRemanufactured ACDelco "Corvette" calibrated valve bodyCustom shift performance calibration (based on customer application)Can be calibrated for stock heavy duty applications as well as high performance applications.Blueprinted tolerences, this is a custom transmission built one at a timeNew Shift SolenoidsNew EPC SolenoidNew PWM SolenoidNew 3/2 SolenoidNew Manifold Pressure SwitchNew Electronic Speed Sensor3 year unlimited mileage warrantySpecify
