Wire Harness "Rebuild" - Who Would You Recommend?
Old 12-17-2013, 01:11 PM
PWagon's Avatar
Default Wire Harness "Rebuild" - Who Would You Recommend?
I have a wire harness for a '03 5.3 Vortec that I need to pay someone to clean up, solder a common ground, and tape it up with non-sticky automotive grade tape. Do you guys have any suggestions? I've already removed all the unneeded wires, and the engine has been running great with the harness. The harness is just ugly as spit, and I want someone to make it look awesome.com.
Old 12-17-2013, 01:24 PM
Sebtarta's Avatar
If you are ok on soldering the ground, then you can get some
TechFlex TechFlex
and make it all pretty.com
Old 12-17-2013, 01:41 PM
superdave84's Avatar
Yeah it sounds like you already got the hard part done. Adding a loom of some sort is a breeze. I don't know what someone would charge to do that for you, but the first place I would look is BP Automotive.
Quick Reply: Wire Harness "Rebuild" - Who Would You Recommend?
