Question for those who used Ford Headers
Old 12-18-2013, 11:06 AM
Nashty's Avatar
Default Question for those who used Ford Headers
I'm doing a swap into a Ford but can only find 1-1/2" primary headers so that's what I'm stuck with.
Did you use just plain LS header flanges or those with stubs used to build headers from scratch?
Any pro tips for me?
Thanks,
Roger
Old 12-18-2013, 11:22 AM
BigEd_72455's Avatar
not a pro tip, but more information would be helpful.
What vehicle you swapping into? Which engine? If a truck, 2 or 4 wheel drive??
Things of that nature make a huge difference in being able to provide an informed response to help you best.
Old 12-18-2013, 12:56 PM
Nashty's Avatar
I have a line on the headers. The injun is your typical 5.3 LM7.
Old 12-18-2013, 02:25 PM
usdmholden's Avatar
Most people just use plain header flanges.
Those 1 1/2" primaries are going to be a smaller OD than the ID of the LS exhaust ports. I doubt that 1.5" exhaust flanges can even be purchased, so you may have to step them primaries down from 1 5/8" or 1 3/4" flanges.
Honestly though, if it were my choice, I'd just run factory manifolds instead of 1.5" headers.
Old 12-18-2013, 08:50 PM
S10xGN's Avatar
Thanks,
Roger
Hey Rog!
I used 1 3/4" BBK 351W swap headers (#1569?), sawed off the Ford flanges and the tubes literally fell into the LS flanges.
Old 12-19-2013, 03:37 PM
Nashty's Avatar
You were exactly who I was thinking about. I'm doing a '78 Mustang II and they don't make larger primary headers. I wonder if the ones you used would work... I'm sure that even those puny 1-1/2" ones would be better than manifolds and present less problems. The headers on my volvo are 1-3/4, wish i could find some of those.
Old 12-19-2013, 09:06 PM
S10xGN's Avatar
Dunno, I got lucky on mine. The big hangup was the conversion to R&P steering and it's "new" column location. I spent a lot of time Googling different headers and eye-balling the DR side for that. One thing about sawing off the flanges, there's quite a bit of "wiggle room" where you can move the header independently of the flange in two planes before tacking/welding...
Old 12-20-2013, 09:49 AM
Nashty's Avatar
Well, i found 351W swap headers for under $600 so that helps. Hedman and Hooker make them. Looks like thats what I'll be using. One nice thing about this car is that i got all the front suspension choices you could want and the stuff is priced right ! Big brake kit, tubular control arms, dropped spindles...
I'm going to use an 8.8 rear in it but the previous owner swapped out the factory 7.5" for an 8" posi. That should sell pretty easy.
Old 12-21-2013, 10:31 AM
boostnut's Avatar
A 78 mustang 2? Did you lose a bet or are you finally building a sleeper?
Quick Reply: Question for those who used Ford Headers
